 GQ-4x stop working, initializing fail
kbzaloka Posted - 10/07/2013 : 18:37:16
Hi, my new programmer buyed on March 2013
stop working, i tried to reinstall soft y driver without success
this are the data i can give you
H/W Re: -(SW Re. 6.23)
USB Driver Re.2.0
* Testing VCC Without Load *
VCC 3.6V test failed, too high (code:0x24a)
VCC 5V test failed, too high (code:0x192)
VCC 5.5V test failed, too high (code:0x15f)
VCC 6.2V test failed, too high (code:0xff)
VCC 6.5V test failed, too high (code:0xff)
* Testing VPP Without Load *
VPP 3.6V/5V test failed, too high (code:0x36e)
VPP 12V test failed, too high (code:0x26b)
VPP 12.7V test failed, too high (code:0x24d)
VPP 15V test failed, too high (code:0x20d)
VPP 21V test failed, too high (code:0x147)
VPP 25V test failed, too high (code:0xd8)
* Test Completed *
tested on two PC, Good USB Cables are used, no fix till now
please help
ZLM Posted - 10/13/2013 : 07:46:34
The programmer need to be sent back for a service. Write to support@mcumall.com and ask for the RMA code for your return.
kbzaloka Posted - 10/13/2013 : 05:54:05
Something wrong with the hardware. You said it still read the serial? what is it?
5.57 KB
this is the serial readed,
and there is some advice to fix the hardware, this programmer
do not have many time, i buy it to have more device support
i have many others working flawless
ZLM Posted - 10/10/2013 : 19:52:35
kbzaloka Posted - 10/10/2013 : 06:18:16
User Name: csluyuan
it says everything
csluyuan Posted - 10/10/2013 : 02:06:17
try to use latest Fifa 14 Coins oftware.
kbzaloka Posted - 10/09/2013 : 16:59:45
i instaled it on a 4th PC with xp only
the programmer counter shows this details
17.58 KB
this 5160 used time is not real,and it resides in the programmer...
kbzaloka Posted - 10/09/2013 : 16:09:28
Originally posted by Richtdi
Hi, did you find a solution to this issue?
Sadly not,but trying...
try to use latest software.
Reconnect the programmer before test it.
already done, the problem seems firmware one
it tries to reconnect but fail.
last try was with CD drivers, which work ok from the very first time
but this time not good
one thing i noticed is that serial is readed from programmer
but history is wrong,it tells about +5100 readed/writed and it is not true ,maybe some 200 or 300 will be more exact, is shows some kind of corrupted data
this value can be resetted?
ZLM Posted - 10/09/2013 : 10:06:08
Richtdi Posted - 10/09/2013 : 06:06:39
Hi, did you find a solution to this issue? Mine is doing the same but coming up with:
VCC 3.6V test failed, too high (code:0x138)
VCC 5V test failed, too high (code:0x9a)
VCC 5.5V test failed, too high (code:0x50)
VCC 6.2V test passed (code:0x7)+
VCC 6.5V test passed (code:0x7)+
VPP 3.6V/5V test failed, too high (code:0x12b)
VPP 12V test passed (code:0x2a)+
VPP 12.7V test passed (code:0xb)+
VPP 15V test passed (code:0x3a)-
VPP 21V test failed, too low (code:0xec)
VPP 25V test failed, too low (code:0x16e)
* Test Completed *
