 MX 25L1005A PROBLEM!! PLS help
brogdan Posted - 01/23/2014 : 12:21:10
hello
i am having trouble flshing the MX 25L1005A
i managed to read the memory, also erase it, but when i tried to write to it, it shows that is writing, but when it goes to verify, i get an error.
i found out that when i go to Lock button, and hit "read" i get this:
(00000H-0FFFF): Block 0 is not protected.(0x1c)
(080000H-0FFFF): Block 1 is not protected.(0x1c)
(0C0000H-0FFFF): Block 2 is protected.(0x1c)
(0E0000H-0FFFF): Block 3 is not protected.(0x1c)
(0F0000H-0FFFF): Block 4 is not protected.(0x1c)
* END *
i tried the "unprotect" button, it sais DONE, but still can't write the memory!
is there something i am doing wrong?
PLEASE HELP!!
osvaldo Posted - 02/09/2014 : 13:08:21
fijate memory this good contacts clean ic adapter and if that does not throw that error. if you can look at the data sheet saver memory to the memory id
ZLM Posted - 01/24/2014 : 11:52:29
Does verify fails on same address every time?
Try to use lower speed and see if it works.
