| T O P I C R E V I E W |
| Necrosaro420 |
Posted - 05/30/2014 : 22:11:42 There is not a setting in the programmer for the AM29F080B-120EC chip. I tried all of the other 29f080 settings and nothing seemed to work. What line of code would I need to add for this? Also using it on the GQ-4X with the ADP-077 Adapter. Thanks |
| 6 L A T E S T R E P L I E S (Newest First) |
| ZLM |
Posted - 06/15/2014 : 23:37:48 You can use regular TSOP40-DIP32 adapter. It should work. You can use ADP-082 + ADP-077 |
| Necrosaro420 |
Posted - 06/08/2014 : 20:24:45 The problem is, there is not an option for the chip in the programmer software. There is a generic am29f080, and a am29f080b*PSOP44. My chip is 40 pin, with B at the end. |
| ZLM |
Posted - 06/07/2014 : 21:06:47 the AM29F080B is a common chip and it should be supported without problem. The TSOP40 adapter is only remapping pins into DIP32. I fyou can confirm the problem is the software algorithm, then a test chip is needed to findout the problem.
IF you can not get the chip ID correctly, then I suspect all your chips. |
| Necrosaro420 |
Posted - 06/06/2014 : 17:26:24 heeeeeelllo. |
| Necrosaro420 |
Posted - 06/02/2014 : 11:24:12 I bought 10, and all do the same. Yes they are 40's. All of the other tsop40's work fine. |
| ZLM |
Posted - 06/02/2014 : 06:51:16 If your chip is TSOP40 chip, then check your chip position in TSOP48 ZIF. The chip should in upper part of the ZIP, the pin 1 should at the top left corner. The voltage jumper on 5V position.
Also, make sure your chip is a good chip.
