T O P I C R E V I E W |
gaosqq |
Posted - 03/30/2015 : 06:23:39 In 2013 I asked if there was a possibility to get 5Volt from programmer. ZLM answered, that this only could be done with external power supply.
I was not happy with the answer, because I could program a 2313 direct in the socket with internal power supply.
After a little research and measurements I could make a adapter with a can6 connection and it worked. Now I can program any AVRISP without external power supply.
 208.25 KB
 212.54 KB
 157.64 KB |
ZLM |
Posted - 05/07/2015 : 15:52:56 Thanks. Here is the ZIF socket pinout:
 4.01 KB |
gaosqq |
Posted - 05/07/2015 : 09:58:56 I have had some questions. The relevant answers:
No, no hardware modifications, No, no software modifications. No, no script. Just the Original GQ-4X
Select device from list and ignore the message (External)Power on target device is required.
Connections:
RST... * *.. Take +5V from here. MISO. * *.. empty SCK... * *.. empty GND... * *.. MOSI
Take care.
ZLM |
Posted - 04/02/2015 : 22:22:08 Thanks. Your target board is small and not other component. So, it can be powered from programmer. |
