 GQ-3x and m27c1000
werejag
Posted - 12/20/2007 :  19:22:14  Show Profile  Reply with Quote
is this chip supported im now sitting on 10 m27c1000 from st and it doesnt seem to write to these.
Edited by - werejag on 12/20/2007 19:23:00
werejag
Posted - 12/21/2007 :  03:10:36  Show Profile  Reply with Quote
had to swap oe and a16 to get the programer to work.
Posted - 12/21/2007 :  09:55:51  Show Profile  Reply with Quote
It should be able to add this EPROM. Do you have datasheet of it?
werejag
Posted - 12/21/2007 :  10:33:04  Show Profile  Reply with Quote
yes it took a bit but found a copy
http://www.questcomp.com/PdfDir/D0224425.pdf
when you add it can i get an update? i really dont want to create a permanent adaptor dont have the parts yet to make a adapter.
Posted - 12/21/2007 :  11:39:18  Show Profile  Reply with Quote
Add this line to devices.txt:
Name="M27C1000",ID="XXXX",Class="27C301",Category="EPROM",MFG="ST",RVpp="5V";
However, you need put a wire jumper between address header A23 to ZIF socket pin 24. And make sure they are contacted well.
werejag
Posted - 12/21/2007 :  11:44:22  Show Profile  Reply with Quote
so no need to make an adptor after this?
Posted - 12/21/2007 :  11:45:59  Show Profile  Reply with Quote
No adapter needed if your chip DIP32 package.
werejag
Posted - 12/21/2007 :  12:06:03  Show Profile  Reply with Quote
yep dip 32
thanks for your help.
Edited by - werejag on 12/21/2007 12:06:27
werejag
Posted - 12/24/2007 :  16:33:00  Show Profile  Reply with Quote
http://bp1.blogger.com/_qkuiJgJSxI0/R3BOGIrr-8I/AAAAAAAAACk/JKonMR7h6dg/s1600-h/Image1.png
i get this error
Posted - 12/24/2007 :  17:50:20  Show Profile  Reply with Quote
Does it always fail at the same location?
Please download the latest R2.05 software.
Check the Double-Write check box too.
Do a blank check before write.
Also, try without external power first.
werejag
Posted - 12/24/2007 :  17:56:02  Show Profile  Reply with Quote
yep fails at same spot both chips.
ill try the above
werejag
Posted - 12/24/2007 :  21:00:46  Show Profile  Reply with Quote
above worked without double write.
i will need to solder a access pin on pin24 becuase im doing a bunch of these
Posted - 12/24/2007 :  23:50:55  Show Profile  Reply with Quote
Yes. You can solder a wire from A23 to PCB back side on ZIF pin 24. So that you can easily change the EPROM without link the jumper wire.
werejag
Posted - 12/25/2007 :  01:00:38  Show Profile  Reply with Quote
im doing these and 27c1001 27c160 27c800 eproms. so permanently tieing the line is alright? i wouldn't think so.
Posted - 12/25/2007 :  19:09:47  Show Profile  Reply with Quote
You are right. The wire only needed for m27c1000.
