 Supported Device List
mcumall
Posted - 05/29/2006 :  11:56:47  Show Profile  Reply with Quote
The new devices will be added regularly, please check the latest list from here:<BR>
http://www.mcumall.com/comersus/store/mcumall_TrueUSBWillemsupportICs.asp
vulcan1
Posted - 07/26/2006 :  09:25:21  Show Profile  Reply with Quote
Is there a reason the ST M27C512-12B1 EPROM is not on this list? Can it be programmed with the generic 27C512 setting?
Posted - 07/26/2006 :  11:41:41  Show Profile  Reply with Quote
yes. The M27C512 is a standard 27C512 EPROM. It will be supported under a generic 27C512.
jmoliere
Posted - 11/08/2006 :  12:26:31  Show Profile  Reply with Quote
Hello,
I looked at the list of supported devices only to find that my device is not on the list.
Is there an alternative to the 'MCM2708C'? The manufacturer of this device is Motorola.
Thanks!
James Moliere
BlueSky
Posted - 11/10/2006 :  02:51:30  Show Profile  Reply with Quote
Most of programmer do not support 2708. I do not know if any direct replacement for it. I doubt it has.
jmoliere
Posted - 11/10/2006 :  17:50:05  Show Profile  Reply with Quote
BlueSky,
Bummer, Thanks!
James Moliere
voxel
France
Posted - 09/29/2007 :  05:46:03  Show Profile  Reply with Quote
Hi :-)
I don't find the D27C4000D from NEC in the list.
It's an UV EPROM, 40 pin DIP, what is the setting for GQ-2X?
Amigalement,
Voxel
Amigalement,
Jean-François, Amiga nuts since 1985 :-)
Posted - 09/30/2007 :  19:49:00  Show Profile  Reply with Quote
I did not find datasheet of it. If you have it please forward it to me. Then I can let you know how to add this chip in GQ-2X supported list.
voxel
France
Posted - 10/01/2007 :  11:41:25  Show Profile  Reply with Quote
Hi :-)
I wasn't able to find one too :-( that's why I asked here :-(
I have only one of it, not mine, that I must read to repair another product that had it's eprom killed.
I can't let it got elsewhere as I must send t back to it's owner.
Amigalement,
voxel
France
Posted - 10/07/2007 :  07:17:39  Show Profile  Reply with Quote
Hi :-)
Finally Igot the datas I needed :-)
You can add it to the device list as UPD27C4000D, NEC as a 27C400 drop pin replacement :-)
Amigalement,
Edited by - voxel on 10/07/2007 07:18:07
Posted - 10/07/2007 :  10:20:33  Show Profile  Reply with Quote
Added this line to devices.txt:
Name="UPD27C4000",ID="XXXX",Class="27C800",Category="EPROM",MFG="NEC",CodeSize="524288",Adapter="16 BIT EPROM ADAPTER 42pin/combo",RVpp="5V",Message="Put chip in 42 pin socket and bottom aligned with the socket.";
fawaz
Posted - 10/20/2007 :  01:32:53  Show Profile  Reply with Quote
Hello,
I looked at the list of supported devices only to find that my device 12C509A is not on the list.
It is possible added the device in the list? ?
lando
France
Posted - 11/09/2007 :  17:29:29  Show Profile  Reply with Quote
hello
is it possible to have support of PIC12F683?
thx
Posted - 11/14/2007 :  00:01:52  Show Profile  Reply with Quote
Name="PIC12C508",ID="XXXX",Class="PIC12F508",Category="MCU",MFG="Microchip",Package="DIP8",ENDPRG_COMMAND="14",PRG_MODE="0"; No ID device need ID="XXXX"
Name="PIC12C508A",ID="XXXX",Class="PIC12F508",Category="MCU",MFG="Microchip",Package="DIP8",ENDPRG_COMMAND="14",PRG_MODE="0"; No ID device need ID="XXXX"
Name="PIC12C509",ID="XXXX",Class="PIC12F508",Category="MCU",MFG="Microchip",CodeSize="2048",Package="DIP8",ENDPRG_COMMAND="14",PRG_MODE="0"; No ID device need ID="XXXX"
Name="PIC12C509A",ID="XXXX",Class="PIC12F508",Category="MCU",MFG="Microchip",CodeSize="2048",Package="DIP8",ENDPRG_COMMAND="14",PRG_MODE="0"; No ID device need ID="XXXX"
Frank D
Canada
Posted - 11/14/2007 :  22:00:28  Show Profile  Reply with Quote
I do not see support for DS1245Y-120 and DS1245Y-120+ chips?
Posted - 11/15/2007 :  01:04:38  Show Profile  Reply with Quote
DS1245Y need to modify the software. Please let us know if you have this chip for testing.
Posted - 11/15/2007 :  01:05:35  Show Profile  Reply with Quote
PIC12F683 will be supported in the future release.
Reply #17
apmdba
Brazil
Posted - 11/27/2007 :  04:36:09  Show Profile  Reply with Quote
Please, is possible to program the SST 25VF080B with GQ-3X ?
The data sheet is here h**p://www.sst.com/downloads/datasheet/S71296.pdf
apmdba
Reply #18
Posted - 12/11/2007 :  21:12:27  Show Profile  Reply with Quote
currently not. but it will be added soon.
Reply #19
lando
France
Posted - 12/27/2007 :  05:19:18  Show Profile  Reply with Quote
For information, I just receive PIC12F683 for test.
thx
