 Can't Program Chips
teknix1
Posted - 03/08/2008 :  11:50:44  Show Profile  Reply with Quote
I just got my new programmer and can't write anything with it.
I've tried many different devices including three different types: AM29F040B, AT29C040A and AM27C040. On the AM29C040A the programmer says that it does not support locking it. This was the reason I bought this programmer.
All I get is a write error right away except for the AM29C040A which seems to program the chip but then verify fails if I take the chip out and put it back in to the programmer.
Any ideas? If I can't fix this, I'll have to return the product.
I tried USB hubs and external power supply. Same thing.
Nic
Posted - 03/08/2008 :  13:45:13  Show Profile  Reply with Quote
All those chips supported.
Check your adapter if it is a right one.
You should be able to get correct ID to confirm the pin contacting no problem.
