 can't erase/write st5P08C3
gzk
Posted - 01/12/2009 :  13:34:20  Show Profile  Reply with Quote
i can read the chip , don't know if the read is accurate , and i can't erase/flash the chip
when i rease it , and make a blank test , it failed .
the chip still contain the same data after erase it .
if i write on it, the data don't change , but i don't have any error message .
i use the zif dip 8 socket buy on the store , and latest soft veersion .
regards
gzk
Posted - 01/14/2009 :  09:34:03  Show Profile  Reply with Quote
help !!!!!!
Posted - 01/14/2009 :  10:10:38  Show Profile  Reply with Quote
Try to use slowest speed?
Do you have second chip for testing?
gzk
Posted - 01/18/2009 :  17:18:12  Show Profile  Reply with Quote
i have test all the speed unsucessfully
the chip is ok , i don't have other but the chip work , is an immo chip from a renault car .
Posted - 01/19/2009 :  09:12:33  Show Profile  Reply with Quote
I need get one of this chip for testing.
Do you have any idea where can I find it?
gzk
Posted - 01/21/2009 :  12:38:36  Show Profile  Reply with Quote
i don't know where you can buy one , but you can find it in edc15 ecu and other .
it's where the immo is stored , in some dash it contain the mileage .
100% sure now the adapter isn't the problem .
i have tried on the same 8 dip smd zif adaptor those serial eeprom
24C04 = success read & write (vag edc15immo)
24C02 = success read & write (old vag tdi immo ), pin 7 need to be ground to remove
write protection
2* 5P08C3 = sucess read , failed write (peugeot,citroen, renault edc15 immo ) , the datasheet said it have a write protect feature on one pin , tried to ground it or vcc it and nothing change still can't write on it .
datasheet :
www.datasheetcatalog.org/datasheet/SGSThomsonMicroelectronics/mXuwrvq.pdf" target="_blank">h p://www.datasheetcatalog.org/datasheet/SGSThomsonMicroelectronics/mXuwrvq.pdf
need your help
Edited by - gzk on 01/21/2009 12:43:57
Posted - 01/21/2009 :  20:24:35  Show Profile  Reply with Quote
What is your programmer hardware version?
Select device AT25040 in software and click on "L" lock button to check if chip been locked.
gzk
Posted - 01/22/2009 :  10:27:29  Show Profile  Reply with Quote
HW GQ4X RE 1.10 SOFT 3.03
NOT LOCKED AT ALL
TRY ANOTHER 94C04 THIS MORNING
READ SUCESSFULL WRITE FAILED
Edited by - gzk on 01/22/2009 10:29:15
Posted - 01/22/2009 :  18:14:49  Show Profile  Reply with Quote
94C04? it is not in the list. So, which device you selected for this chip?
I will post new beta software later for ST95P08 update for testing.
gzk
Posted - 01/22/2009 :  19:07:31  Show Profile  Reply with Quote
sorry not 94C04 BUT 24C04
that's i don't understand is i have already success to write one , and this time it's failed .
Posted - 01/22/2009 :  21:01:08  Show Profile  Reply with Quote
24C04 should be no problem.
Try following build for 5P08C3:
www.mcumall.com/download/TrueUSBWillem/GQUSBPrgRe4.0Beta2.exe
Uninstall the old version first.
Select 5P08C3 from software.
Let me know the exact error message if it fails.
gzk
Posted - 01/23/2009 :  13:58:16  Show Profile  Reply with Quote
* if i uninstall old version , after installing new version , the programmer doesn't woork .
windows cann't load the driver .
if you install the driver manually it doesn't work .
* i have reinstall back the last version (non beta) and after reinstall thhe version you gave me , and now the programmer is working .
but same problem with this chip :
h**p://img19.picoodle.com/img/img19/3/1/23/f_5P08C3m_1d3ef78.jpg
h**p://img26.picoodle.com/img/img26/3/1/23/f_DSC02983redm_15efed8.jpg
h**p://img26.picoodle.com/img/img26/3/1/23/f_DSC02987redm_1fbcb26.jpg
Edited by - gzk on 01/23/2009 14:00:05
Posted - 01/24/2009 :  10:40:42  Show Profile  Reply with Quote
Your chip position seems OK. But makesure the chip pin 1 is at the top-left conor.
Checked software again and did not find anything wrong.
I need a chip for testing in order to find out why.
