 Problem burning 27C256
cucaracha
Posted - 01/24/2009 :  05:03:52  Show Profile  Reply with Quote
I have a GQ-3X programer and know when I try to burn 27C256 eprom at 51% gives the error write failed adress=0x004023, buffer=0x05 device=0x00 even if i change eproms I allready tried two.
Please help
Best regards.
cucaracha
Posted - 01/24/2009 :  17:20:45  Show Profile  Reply with Quote
If bothe chips failed at different location, then check the chip pin contact in ZIF socket.
Also, use slower speed or try use a external power see if it makes different.
Does programmer program any other chips?
