 39vf160 and 28f160 and again problem
nicotinetar
Posted - 02/06/2009 :  20:22:44  Show Profile  Reply with Quote
Hi again me ,
i setup your sending 4.x program and i try 28f160 and 39vf160 but i have an error . At 28f error you know .
at 39vf160 , when i try to read id this chip sometimes sst 39vf160 sometimes FFFFF some times sst not library ...
i programmed 29lv160attc and 29w800 flash 8/16bit adaptor and i havent any mistake. read erase write and verify ok but 16 bit chips (28f and 39vf) i got errors. generally i can read but not erase and write.
my programmer or adaptor have and hardware errors?
nicotinetar
Posted - 02/07/2009 :  14:03:36  Show Profile  Reply with Quote
ZLM can you answer me ?
Posted - 02/07/2009 :  17:55:08  Show Profile  Reply with Quote
I got one TE28F160CB3 chip for testing. and I tested it on both GQ-3x and GQ-4X. Both are succeed without any problem on "TSOP48 16 bit adaper V2.0" So the sofrware Re4.0Beta3 has no problem.
www.mcumall.com/download/TrueUSBWillem/GQUSBPrgRe4.0Beta4.exe
Please check the Vcc jumper is on the 3.6 V position, the chip jumper on the 28FX00 position, A19,A20,A21 are connected.
I do not have 39vf160 for testing.
nicotinetar
Posted - 02/10/2009 :  18:01:17  Show Profile  Reply with Quote
Thank you , i ll try ...
fox_el_negro
Mexico
Posted - 02/24/2009 :  22:33:17  Show Profile  Reply with Quote
i have same problem cant program the intel te28f160 cb3.
i only program one with the 39vf160 configuratio, then i try to program another chip and dont work
check and recheck configurations everyting ok 3 6 jumper on 28fxx ok 19 20 21 ok coclusion programers have failures!!!!!
c64
Posted - 02/24/2009 :  23:57:22  Show Profile  Reply with Quote
can you take a close look picture on your chip in adapter with the programmer?
So that I can get a close look of your configuration.
fox_el_negro
Mexico
Posted - 02/25/2009 :  00:02:00  Show Profile  Reply with Quote
ill send pictures very soon.
now were is the beta4 sofware?
link is down
c64
fox_el_negro
Mexico
Posted - 02/25/2009 :  00:03:13  Show Profile  Reply with Quote
and tanks a lot to take your time on answer!!!
c64
Posted - 02/25/2009 :  08:20:21  Show Profile  Reply with Quote
use Beta5B:
www.mcumall.com/download/TrueUSBWillem/GQUSBPrgRe4.0Beta5B.exe
