 Setup for M95128W6 serial eeprom
paulo19552003
Brazil
Posted - 03/11/2009 :  05:52:18  Show Profile  Reply with Quote
Hello
My name is Paulo and I live in Brazil. The M95128W6 is not present on device.txt. I intend to burn the above chip (from ST) using the setup for AT25128AN SU27. I have checked the datasheets and both devices are electrically the same. Can I do that with no risk ??? Also I would like to edit the device.txt and add this ST component. Thanks in advance.
Paulo
Posted - 03/11/2009 :  21:48:19  Show Profile  Reply with Quote
Yes. You can try by following:
Name="M95128",ID="XXXX",Class="AT25128",Category="SERIAL_EPROM",MFG="ST";
Let me know if it works.
