 GQ-4X & W25X32 (Winbond)
poppycomp
Romania
Posted - 03/13/2009 :  22:52:12  Show Profile  Reply with Quote
I tried to write W25X32 and it did not work every time. Any suggestions?
Edited by - poppycomp on 03/13/2009 22:53:22
Posted - 03/14/2009 :  10:18:45  Show Profile  Reply with Quote
Please provide more details:
1. Is it on ZIF or in circuit programming?
2. What is the exact error message?
3. What means "not work every time"?
4. Did you try to use slower speed?
poppycomp
Romania
Posted - 03/14/2009 :  15:05:33  Show Profile  Reply with Quote
Yes, is it on ZIF .Not error message on writing.Error message on verifying (when compare data ).Yes,I tried use slower speed.
Sorry,but I don’t speak english.
Posted - 03/15/2009 :  08:55:07  Show Profile  Reply with Quote
Can you get the ID correctly?
What is the address on verify error?
Does it always fail on same address?
poppycomp
Romania
Posted - 03/15/2009 :  12:19:17  Show Profile  Reply with Quote
This is the result after erase and write jobs.Is not a constant error.
Device ID (HEX) :EF3016 Winbond W25X32
104.3 KB
102.8 KB
104.89 KB
100.06 KB
Edited by - poppycomp on 03/15/2009 13:14:19
Posted - 03/15/2009 :  22:40:55  Show Profile  Reply with Quote
Did you erase the chip and do a blank check?
poppycomp
Romania
Posted - 03/15/2009 :  22:52:22  Show Profile  Reply with Quote
Yes,I tried to delete before write but information still remaining.
I managed to write 5 pieces but I have a lot of flash written.
Last ten attempts were failed.
21.63 KB
Edited by - poppycomp on 03/15/2009 22:53:56
Posted - 03/15/2009 :  23:03:32  Show Profile  Reply with Quote
It seems this chip is unable to be erased. It is possible that the chip is a bad chip.
poppycomp
Romania
Posted - 03/16/2009 :  01:10:27  Show Profile  Reply with Quote
I've managed to write 5 chips (w2tx32) after several failed attempts; I could not find a solution to have successful flashing each time.
The bin file is written without errors, but at read on the chip its still the initial information before the write
the average flashing time is around 20 mins on max speed
Posted - 03/18/2009 :  09:51:31  Show Profile  Reply with Quote
The chip must be erased before can be correctly programmed new data.
So, use the slow speed to repeat the erase untill it is erased.
Change to normal speed for writting.
poppycomp
Romania
Posted - 03/19/2009 :  05:07:22  Show Profile  Reply with Quote
the data on the chip cannot be erased regardless of the speed used ...
when the next version of software will be available? Also any other solution for this?
Posted - 03/19/2009 :  23:28:06  Show Profile  Reply with Quote
We will take look to this.
poppycomp
Romania
Posted - 03/27/2009 :  23:59:08  Show Profile  Reply with Quote
GQUSBprg 4.01 and GQ USB Driver 2.01
With new software and new drivers works ( speed "0" ).
