 Where is AM29F016B option???
Necrosaro420
Posted - 01/20/2010 :  14:14:27  Show Profile  Reply with Quote
I have the tsop adapter, can burn 29f032 fine, but there isnt an option in software (version 5) to turn AM29F016B how can I add this to the list so I can burn this chip? Thanks
osvaldo
Argentina
Posted - 01/20/2010 :  20:14:27  Show Profile  Reply with Quote
DERVICE
Name="AM29F016B",ID="01bf",Class="AM29F016B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
osvaldo tecnico
Necrosaro420
Posted - 01/21/2010 :  16:18:25  Show Profile  Reply with Quote
Heya thanks, I put this in the devices, but it says when I load up program:
The class AM29F016B is not found. Parse "Devices.txt" error on device AM29F016B
Necrosaro420
Posted - 01/22/2010 :  11:20:50  Show Profile  Reply with Quote
Anyone have any other ideas?
Posted - 01/22/2010 :  16:12:35  Show Profile  Reply with Quote
What is your chip package? TSOP40 or TSOP48
Necrosaro420
Posted - 01/22/2010 :  17:39:41  Show Profile  Reply with Quote
TSOP40
Posted - 01/22/2010 :  23:25:45  Show Profile  Reply with Quote
You need TSOP40B adapter
See:
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4418
If your programmer is GQ-3X, then you can use this one:
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4404
Name="AM29F016B*TSOP40",ID="01AD",Class="29F040B",Category="FLASH",MFG="ST",CodeSize="2097152",DIP="100011110101",Adapter="ADP-082 OR ADP-076 TSOP40B";
Necrosaro420
Posted - 01/22/2010 :  23:42:30  Show Profile  Reply with Quote
I have the TSOP40 adapter, trying to burn a AM29F016B, exact same physical size and pins as M29F032D which I have no issues burning. I added the line you suggested and it did not give me an error when I loaded it up, ill do a burn tomorrow and see how it goes. Thanks!
Edited by - Necrosaro420 on 01/22/2010 23:43:58
Necrosaro420
Posted - 02/27/2010 :  14:51:11  Show Profile  Reply with Quote
I have the adapter you referenced above. When I try to burn the AM29F016B, it burns, then I get this message:
VerifyFailed, Address=0x002CCC, Device=0x09, Buffer=0xFF
They will not verify
Posted - 02/27/2010 :  21:36:15  Show Profile  Reply with Quote
you have to check chip pin contacting in the adapter. You may need a magnify glass.
Necrosaro420
Posted - 02/28/2010 :  19:20:38  Show Profile  Reply with Quote
Heya, I already do that, they are lined up perfect
Posted - 03/02/2010 :  10:22:31  Show Profile  Reply with Quote
Chip problem?
Necrosaro420
Posted - 03/02/2010 :  15:57:49  Show Profile  Reply with Quote
Shouldnt be, does it on all 6 I have, purchased 2 different places
Ziggy587
Posted - 06/27/2010 :  05:47:33  Show Profile  Reply with Quote
I too am trying to burn an AM29F016B on a GQ-4X. I'm using the same adapters as referenced above, and I have also burned 29F032's without a problem.
I added the line of code from above posted by ZLM and did not get an error message upon loading the software, but I was not able to program successfully. It failed to verify for me too.
Not sure if this info helps, but I read the chip back and loaded it into a hex editor to compare against the original file. It found about 20 difference, all 1 byte large.
Posted - 06/27/2010 :  06:57:38  Show Profile  Reply with Quote
If some one can send a testing chip to support@mcumall.com, then the problem can be found.
manmaoyy
Posted - 07/09/2010 :  22:23:06  Show Profile  Reply with Quote
www.dvdsetshop.com/products/Smallville-Season-9-DVD-Box-Set-DVDS-2284.html Smallville seasons dvd
[url www.dvdsetshop.com/products/Smallville-Season-9-DVD-Box-Set-DVDS-2284.html] Smallville purchase
Edited by - manmaoyy on 07/09/2010 22:24:04
