 TE28F320
ingrds
Venezuela
Posted - 02/09/2010 :  13:40:11  Show Profile  Reply with Quote
I HAVE THIS FLASH FOR ROUTER I NEED INSTALL THE NEW FIRMWARE
Posted - 02/09/2010 :  23:24:14  Show Profile  Reply with Quote
This chip is not tested. You can try to use ADP-042 TSOP48 16 BIT ZIF Adapter.
ingrds
Venezuela
Posted - 02/20/2010 :  08:02:25  Show Profile  Reply with Quote
yes i have it but what select in the device
Posted - 02/20/2010 :  23:53:24  Show Profile  Reply with Quote
Add following lines into devices.txt file:
Name="TE28F320C3T",ID="8988C4",Class="TE28F160C3T",CodeSize="33554432",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="TE28F320C3B",ID="8988C5",Class="TE28F160C3B",CodeSize="33554432",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
