 M27C801 cannot/won't write, GQ-3X
stevenc
Posted - 02/20/2010 :  20:03:27  Show Profile  Reply with Quote
I'm having some problems programing a M27C801. The chip is blank.
After the programmer is done writing and verifying and doing another blank check, it gives me this.
ID check OK
Blank checking... Code
Elapsed time: 45.77 seconds.
Chip is blank
Writing... Code
Elapsed time: 228.12 seconds.
Device write completed OK
Verifying... Code
Device is verified
Elapsed time: 45.94 seconds.
ID check OK
Chip is blank
What's going on? Is there some kind of jumper I need to set on the programmer for it to program 27c801 chips?
Edited by - stevenc on 02/20/2010 20:10:06
stevenc
Posted - 02/20/2010 :  21:03:53  Show Profile  Reply with Quote
Tried at a slower speed, same results except for failing to verify.
<<M27C801>>
Speed = 5
ID check OK
Writing... Code
Elapsed time: 935.23 seconds.
Verifying... Code
VerifyFailed, Address=0x080000, Device=0xFF, Buffer=0x00
VerifyFailed
Elapsed time: 727.02 seconds.
ID check OK
Elapsed time: 1139.30 seconds.
Chip is blank
Necrosaro420
Posted - 02/20/2010 :  21:10:31  Show Profile  Reply with Quote
Pretty much the same thing here in the 5.0 software. Burns, but mine fails. I do a blank chip afterwards and it says the chip is blank, but then I click the code tab to make sure the file was loaded right that I was trying to burn, and all the info is there.
stevenc
Posted - 02/20/2010 :  21:20:15  Show Profile  Reply with Quote
Wondering if this could be an issue with the chip not getting enough power?
stevenc
Posted - 02/20/2010 :  21:46:12  Show Profile  Reply with Quote
FIXED, I think.
I used a external power supply, my good old sega genesis model 1 PS (DC 10V 1.2A).
I hope this power supply adapter won't do any damage in the long run?
<<M27C801>>
Writing... Code
Elapsed time: 413.60 seconds.
Verifying... Code
Device is verified
ID check skipped
Elapsed time: 0.46 seconds.
Device blank check failed at address: 0x000000, Read= 0x00.
Blank check failed
ID check skipped
Blank check failed
ID check skipped
Verifying... Code
Device is verified
Elapsed time: 45.82 seconds.
ID check skipped
Reading... Code
Elapsed time: 45.67 seconds.
Read completed.
And the code looks like it's fine.
stevenc
Posted - 02/21/2010 :  09:02:40  Show Profile  Reply with Quote
Got it to work without the power supply.
I just wasn't loading the rom properly apparently. :S
Necrosaro420
Posted - 02/21/2010 :  16:47:33  Show Profile  Reply with Quote
Well I have the 5.0 loaded on 2 pc's. The programmer on one will burn the chip, but burns it blank. On the other using the exact same chip and exact same file, it burns fine.
Bad_Ad84
Posted - 02/22/2010 :  00:39:39  Show Profile  Reply with Quote
sounds like usb port isnt providing enough power, try ac adapter on the one that fails.
