 NAND HY27UGO88G5B
od-lambda
Spain
Posted - 12/24/2010 :  10:00:45  Show Profile  Reply with Quote
Hi to all.
One days ago i try to recover pendrive chip 1gb this chip ID is:
HY27UGO88G5B
HY27UG088G5(D)B 57nm 1Gb 128KB DDP 3.3V / x8 TSOP / LGA NOW 2CE / Dual CH.
I can read with any programmer for ejample Gq4-x OR ANOTHER???
Posted - 12/29/2010 :  22:26:20  Show Profile  Reply with Quote
This chip only supported on hi-end programmer. Such as VP490, Xeltek 500S etc.
od-lambda
Spain
Posted - 12/31/2010 :  12:50:10  Show Profile  Reply with Quote
Xeltek 500S i think that not support this chip:
h**p://www.xeltek.com/SuperPro-501S-product-17207 (see the device list supported)
and VP490:
h**p://www.weilei.com/indere.htm
i dont found this programmer and chip in this list.....
Thanks for help....i wait response
regards
Posted - 01/01/2011 :  09:39:34  Show Profile  Reply with Quote
Checked again, it is VP990 and Xeltek 5000E.
Bad_Ad84
Posted - 01/04/2011 :  03:04:35  Show Profile  Reply with Quote
Elnec beeprog+ works fine too.
tps_star
Posted - 01/05/2011 :  07:11:21  Show Profile  Reply with Quote
VP990 and Xeltek 5000E and Elnec beeprog+ is expensive
i can send to you cheaper than programmer with support over 8000 device and you can add new device
Bad_Ad84
Posted - 01/05/2011 :  11:57:32  Show Profile  Reply with Quote
Beeprog+ is nearly 60000 devices and likely much faster than what you are offering.
But for some, speed isnt a requirement.
Bad_Ad84
Posted - 01/06/2011 :  04:26:15  Show Profile  Reply with Quote
and the name/model of the programmer is?
Bad_Ad84
Posted - 01/06/2011 :  04:29:30  Show Profile  Reply with Quote
also, 40 pin means adapters are going to be expensive?
as the tsop/whatever else adapters wont be universal ones.
universal tsop48 adapter is like $30
Posted - 01/07/2011 :  23:54:21  Show Profile  Reply with Quote
Sorry. Advertising in the forum is prohibited. All advertising posts will be deleted.
This forum is only for technical discussion.
od-lambda
Spain
Posted - 01/14/2011 :  12:02:42  Show Profile  Reply with Quote
Hi to all thanks for compare products.......
To read this NAND CHIP its very hard....i buy the xeltek programmer because its "the most cheap" for NAND FLASH, very fast and very easy to use.
But mcumall have more adapters and good programmers to small chips.Its a good solution and cheap.But i think that mcumall search o research about this chips.Its posible open more market....
But talk about this chip its very nice to research about how to work about this......
If the people like to know how tu run this flash chips check this:
ht t p://en.wikipedia.org/wiki/Flash_memory
Its very interesting.
regards and sorry ZLM
