 load more .HEX files
Jerry
Czech Republic
Posted - 02/22/2012 :  07:03:33  Show Profile  Reply with Quote
GQ-4X with soft Rev. 6.14c
If I load the .HEX file, then the rest of bufer is filed by "00". But the right value for this is "FF".
If I load the second file, placed in the rest of bufer, then the first part of bufer is owerwrited by "00".
It means: I am not able load to bufer more .HEX files. With another programer (Elnec) is this not problem.
Jerry
Posted - 02/23/2012 :  00:22:15  Show Profile  Reply with Quote
If you want to combine two files, then you need to use File->Combine Files to Buffer.
This will combine multiple .bin file into the buffer.
If your files are in .hex, then you need to save your files into .bin first.
