 Pic 16F722
mockba
Posted - 01/29/2013 :  20:42:07  Show Profile  Reply with Quote
Hello there ... I don't see it on the selection list, but it exists on the Devices folder (PIC16F722.dev).
How can I use that file?
I am sorry if this is a dumb question, but I couldn't figure out how to load it.
Thanks a lot in advance,
Marcelo "Mockba" Dantas.
Posted - 02/01/2013 :  02:03:12  Show Profile  Reply with Quote
I think you can try to add this chip into the software.
Try this line:
Name="PIC16F722",ID="1880",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="256",Package="DIP28",Speed="5",BEGPRG_COMMAND="18",ENDPRG_COMMAND="17",BEGERASECHIP_COMMAND="8",ERASECHIP_COMMAND="1F",PRG_MODE="0",CFGByteLabel="CP CCPMX DEBUG WRT1 WRT0 CPD LVP BOREN MCLRE FOSC2 PWRTEN WDTEN FOSC1 FOSC0";
mockba
Posted - 02/01/2013 :  17:33:23  Show Profile  Reply with Quote
Hi ZLM,
Thanks, I will add this line and give it a try.
Is there any guide or how-to on using these .dev files? What are they used for?
Is there a more advanced guide or how-to on adding devices to the devices.txt file? I see some information on page 21 of the user guide, but how can I come to the same line you suggested me?
How did you find the ID=1880?
What are the possible Classes?
What are the possible Categories?
How did you get to the commands? Is this something from the datasheets?
Thanks,
Marcelo.
Posted - 02/01/2013 :  20:47:39  Show Profile  Reply with Quote
The .dev file has most of information about this chip. I found the ID from .dev file.
The datasheet tells you about the chip packaged available.
mockba
Posted - 02/04/2013 :  12:01:30  Show Profile  Reply with Quote
Thanks.
Is there any documentation on how to create a .dev file? Any more in depth documentation than the user guide?
Thanks a lot,
Marcelo.
Posted - 02/04/2013 :  20:50:02  Show Profile  Reply with Quote
you do not need to create the .dev. It is standard file of Microchip.
mockba
Posted - 02/07/2013 :  10:24:52  Show Profile  Reply with Quote
Got it ... so it is a description of the device coming from Microchip themselves. I though it was some device description to add custom devices to the GQ-4X.
You answered my question.
Thanks,
Marcelo.
Generated in 0.38 sec. Snitz Forums 2000
