 My (GQ-2X) has arrived, now what?
ukez
Posted - 07/23/2007 :  13:27:13  Show Profile  Reply with Quote
Hiya guys I've now got my True USB Willem Programmer (GQ-2X), I need to copy the information from one eprom to the other which is the same type; can you tell me if im doing this right please?
This is what I've done so far
1)I mounted my DIP32 to PLCC32 converter to my True USB Willem Programmer.
2)I then inserted the eprom i wanted to copy (M27C512 70c1 PLCC32 OTP EPROM) into the PLCC32 socket.
3)I selected the "DEVICES" option from the GQ application drop down menu, and then chose the device type that i'm using (M27C512).
4)Once i selected the correct device I noticed the dip switch diagram located in the GQ application display changed, it ended up displaying the correct "dip switch" setting for my setup.
5)I configured the dip switch according to the diagram.
6)As soon as i did this, and selected the "READ" tab I noticed their was a change in the "CODE MEMORY DISPLAY". Is this right?
7) I then selected the "SAVE" tab from the dop down menu of the GQ application, and saved the file into a directory i created called (C:\EPROM) and saved the BIN file there.
Is this correct so far?
I didn't use an external power supply, I didn't attempt to as it seemed to read the original eprom without it. Should I of used the external power port for this type of eprom?
I only ask as when I checked the information on the type of eprom that I'm using its spec shows the following:
M27C512 512K UV EPROM and OTP EPROM
Attributes
Category EPROM
Package PLCC32
Type One Time Programmable (OTP)
Size 512K
Organisation 64Kx8
t acc (ns) 70ns
Vpp (V) 12.75V
Icc (mA) 30mA
Icc stby (mA) 1mA
T (°C) 0 #8594; 70°C
Should i have used a 12VDC PSU?
I'd appreciate it if you can help with my query's, If I've gone wrong anywhere please let me know.
Can anyone explain the correct way to write information to this particular type of eprom that I'm using
I'm guessing i should just insert a blank eprom in the programmer, open a new GQ application. Select the "OPEN from the drop down menu of the GQ application, then select the copy of the BIN file from the original eprom, the BIN file i saved in the (c:\eprom) directory.
Then im assuming i then just select the "WRITE" & "VERIFY" tick box's under the "BATCH RUN" on the main screen, then select the "RUN" icon.
Is this correct? I hope you can help!
Posted - 07/25/2007 :  13:24:35  Show Profile  Reply with Quote
In step 1, the PLCC32 27C512 need to use PLCC32-DIP28 adapter.
Then from step 2 to 7 are correct.
For the best, you may want to click on ID button to read chip ID after step 5. This will confirm all your setting and the software selection are correct.
Once you read and saved the your original chip, then you can insert the new blank chip into PLCC32-DIP28 adapter, then do a blank check to confirm it is blank. If so, you can open the file you saved and write it.
You do not need to use 12VDC power.
ukez
Posted - 07/26/2007 :  13:01:55  Show Profile  Reply with Quote
ZLM, thank you for your help, much appreciated.
I'll give it a go now.
Regards
UKEZ :)
ukez
Posted - 07/28/2007 :  18:53:19  Show Profile  Reply with Quote
Hi ZLM, I followed the information you suggested and it has worked.
You and this forum have been great, thanks for all your help!
Edited by - ukez on 07/28/2007 18:53:53
