 mx29lv008cbtc
ingrds Posted - 10/07/2008 : 08:48:31
helllo i have GQ-3x rev1.0 how i can update it and need programmer mx29lv008cbtc
anniel Posted - 09/07/2016 : 02:35:33
Yes
F-bone Posted - 09/07/2016 : 01:10:24
apologies for this following dumb question.. I need both adapters?
ZLM Posted - 09/05/2016 : 20:48:48
Yes. You also need an ADP-077 top ZIF socket.
F-bone Posted - 09/05/2016 : 10:13:18
I also need to program this chip with GQ-4X (older model). Is this adapter the right one?
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4418
br
george
ZLM Posted - 10/07/2008 : 15:10:05
This chip should be supported on gQ-3X.
Try to add following two lines into devices.txt
Name="MX29LV008B",ID="C237",Class="29LV800B",Category="FLASH",MFG="Macronix",Adapter="TSOP40A
adapter",VCC="3.6V",Message="Set the adapter to 5V jumper position. And connect A19 from adapter to programmer";
Name="MX29LV008T,ID="C23E,Class="29LV800T,Category="FLASH",MFG="Macronix",Adapter="TSOP40A
