 AM28F020/scriptDP-21
SCS Posted - 05/29/2011 : 14:34:16
Can read fine verify read erase and verify but when I go to wright it stops at 25% with this eror Write failed, Address=0x010001, Buffer=0xB2 Device=0xF2 help thanks
ZLM Posted - 04/08/2012 : 20:52:02
If you can confirm the chips OK, then check programmer A16 pin voltage during the reading.
It should have voltage change during the reading.
SCS Posted - 04/06/2012 : 15:14:24
I really would like to figure this out trying again and I'm getting write fail address=0x010000,buffer=0x05DEvice=0xFD on the chips
SCS Posted - 04/05/2012 : 13:14:27
A16 pin can't be a problem with 6 different roms
ZLM Posted - 06/01/2011 : 00:04:11
It seems the A16 pin is not connected well. Check you chip A16 pin if connected good with adapter/programmer.
