 [Solved] Read HN27C64G fails
lionel7474 Posted - 06/28/2016 : 20:38:47
Good evening,
I have the following system and software (Windows XP SP3):
H/W Re: GQ-4X Re-2.20(SW Re. 6.38)
USB Driver Re.2.0
Software Re. 6.38
<<HN27C64>>
Apply external power !
When reading a few times a HN27C64G, the content (the buffer) and the checksum are always different. The Verify command also fails. This EPROM works well when used in its environment.
When reading a different EPROM with the GQ-4X Re-2.20, it works perfectly.
Is the HN27C64G supported?
Regards,
Lionel
lionel7474 Posted - 07/01/2016 : 13:44:58
Thank you for the suggestion.
Here is what finally worked:
1. Read the EPROM many times (11 to 19) until the checksum is constant.
2. Now the content can be read perfectly for all EPROMS.
3. When I turn off the GQ-4X, then when I turn it on, I have to go through the above step 1 until the checksum is constant.
I tried it on two PCs (one with Windows XP, one with Windows 10 with a fresh install of the software): the behavior is the same. I wonder if there are capacitors or other components that are aging? I bought the GQ-4X new last summer (2015).
Regards,
Lionel
ZLM Posted - 06/28/2016 : 21:09:41
HN27C64G supported.
Check the pin contacting.
